maboat
- Lake Ray Hubbard, TX
The ACR won't make batteries charge any faster than a shore charger. If you plug in a shore charger for less than an hour, it won't do much for a drained battery bank. Likewise, the engines won't charge drained batteries any faster. You need to cruise for hours to get any real charging benefit. This is not an ACR flaw, its normal behaviour. Its no different with shore charging. It ain't gonna make much difference unless you supply charging current (from engines or from external charger) for several hours.
Bigger engines with bigger alternators don't charge batteries any faster. What they do have is the ability to supply more current to more things running at the same time charging the batteries. But neither system is going to charge drained battery banks unless the engines are running for hours.
The benefit of the ACR for us is that is reduces or even eliminates the drain on the house bank when the engines are running. Whether ACR or manual switch, I don't expect the engines to fully recharge drained house banks. But it DOES reduce or stop the battery drain while the engines are running.
Then you'll know exactly what's happening and why.
and not just the stereo, but turn off everything (on both banks) that is not required until the voltage stabilizes.
Time to replace those broken dual volt-meters.I have the newer one. And it does work... When I hook it up to a battery charger at home, I have watched it combine batteries. But when on the water, I've never seen the running engines generate enough of a charge to the house to make it combine. I suspect it does more like what @David Analog was saying. It combines, and the house battery is too drained, so it almost immediately un-combines, and then waits.... rinse, repeat.
ditto.Simple voltage measurements at key points prove this behavior.
So if you are in deficit then turn 'Off' the dang stereo for long enough for the ACR to stay latched. It won't take that long to build a sufficient charge while underway at a good clip. Then bring the stereo on line a while later and take it easy.
The "add-a-battery" kit includes the dual-circuit battery switch. That switch has a manual combine position. So if you install the full kit, you get automatic operation with manual override when needed.So a manual combine switch makes more sense of our Yamaha's? @David Analog
