Welcome to Jetboaters.net!
Yes it would. And I thought that is what I would do. Then I realized that every time you change something, the bow stop position changes. i.e. such as replacing bunk board, winch, roller. When I got this boat home, the roller was deformed and had eye bolt marring and it was off center. All it takes to realign is to loosen the two pinch bolts and reset it to the bow.
It is an easy fix @GTBRMC , just trying to find the best way to do it. You wouldn't believe the actual bow stop post...it is BEEFY! But the way it secures and adjusts is a good design, just poor execution. They should have designed either a shim plate or ferrules on those bolts to take up the slack. Either that or better placed holes to snug it with the bolts. There is zero torque spec for those bolts in the trailer manual too. I am going to call them next week and have a conversation about this, because I don't want to bend it where I can't get it off if I had to. If I did bend it, it would scratch the hell out of the tongue frame doing so. Anyway, it sure doesn't move like the MFI...but it is possible to put enough pressure on it to pivot it, and an uphill or jack rabbit start could cause it to pivot backward, although that isn't near as likely. If you use previous procedures to take the slop out and snug the boat against the bow roller, by doing a hard stop, you most certainly will pivot the post.
No doubt that the Shorelander is a much better trailer than the MFI. It is an area where I think Yamaha is not taking the cheapest way out. From what I can see, it is a much better trailer than the MFI.
The jack
Mount is incorporated into the bow post. If I moved it, I would have an ugly blank spot and have to add some sort of universal that would also detract
From a nice looking trailer. IMO.
