Seno
- Lithia, Florida
I bought a 2022 212 and since new there have been several QC trailer issues. The trailer has been losing bearing buddy caps somewhat regularly, at first I thought it was petty theft at the boat ramp. It turns out the brakes have been dragging which was heating up the grease and causing pressure forcing the caps to be pushed off. At first inspection I thought there was air in the line, so I bled them but the issue persisted. One of the calipers had a loose banjo bolt holding the brake line to the caliper, leaking fluid. I brought the trailer to the dealer and while they were testing the brakes I noticed the shaft between the axles clamped to the leaf spring was moving back and forth 2-3 inches. That could be really dangerous! The dealer is trying to have shorelandr warranty pads, rotors and the shaft...... Check your trailer vigilantly, there seem to be more QC issues with the trailers than the boats (I just might be a lucky one with no boat issues). Also rust was present on the slide assembly below the housing, which I am assuming was from a brake fluid leak/spill from the mfg or dealer. Very dissatisfied with the trailer currently, hopefully they do the right thing. Good luck!
