Ben Okopnik
- Tampa FL
- Other
- Other
- Other
Hey, all -
According to the manual, the SJ has a "bilge siphon" feature in which the big pump is also used to evacuate the water out of the bilge at speed. This sounds pretty cool, but there are all sorts of warnings about keeping the siphon break open and locating it above the waterline - which all makes sense. However, the PO of this boat did a... let's just call it a "custom" engine installation... in which nothing seems to have been done by the manual. As a result, the siphon hose comes up from its fitting, goes above the water line, and then simply splits into two hoses (which drop down on both sides of the bilge) via a tee. No sign of a vacuum break anywhere - and I do get water in the bilge after a run at speed, probably about a gallon in 15 minutes. Nothing coming in while I just sit there; only during, or after a fast run.
(He had also routed the bilge pump hose without raising it above the waterline; I found out about this when water fountained up through the cockpit drain while we were fishing in the middle of the bay after the waves had been slapping the hull for a while. That's now fixed, the SJ got a good rinse out of the deal, and the bilge pump float switch is the very next project I'm doing on this boat.)
So my question is, should I just drill an .020 hole - which is supposed to be what was in the original siphon break - in the tee fitting and call it done? The manual doesn't list a part number for a vacuum break (unsurprising, since it's not really a part of the jet or the engine, just a necessary installation feature) and the breaks I'm familiar with are a good bit bigger than that. The tee is easily accessible via the round panel in the back of the boat, so I could easily check it as part of regular maintenance.
