slapin on some vinyl
84rzv500r
Lower Keys MM29
need to use the AR210 next sunday for WetStock so the pressure is on...
I use 1.125" thick closed cell neoprene foam... its soft enough to sit on and firm enough to walk on... also i try to avoid seams if I can as they tend to rip over time and let water into the open cell foam... When I took the OEM engine hatch cover off it must have weight 150 lbs as it was always water logged.. i do have a consew 220 industrial machine and did some test cushions with french seams and the seams collect dirt too... Soooo no seams and no open cell foam...
attachment - 2022-05-22T105517.532.jpgattachment - 2022-05-22T105530.431.jpgattachment - 2022-05-22T105541.956.jpgattachment - 2022-05-22T105558.612.jpgattachment - 2022-05-22T105614.038.jpg
84rzv500r
Lower Keys MM29
and more...
attachment - 2022-05-22T150248.994.jpgattachment - 2022-05-22T150259.918.jpg
84rzv500r
Lower Keys MM29
well its good enough for now... still adjusting so the bolts aren't drawn down.... im pinched for time... i can pull the staples and re adjust around the inside curve.. ran outta daylight... BBB will have a place to lounge at Wetstock....
attachment - 2022-05-22T204755.608.jpgattachment - 2022-05-22T204802.904.jpg
