I did check the fuses - there a 3 amp and a 20 amp and they all looked good. I just went with a sight test as when they blow it is usually noticeable. Just in case though I switched the spares with the ones in use. I never did actually pump fuel, but, when I removed the fuel pump from the hose supplying fuel to the engine the hose was full of fuel. And just to make sure I splashed some in my eye. Good thing I was not burning the
@Glassman aromatic candle at that time!
I'm wondering if it could be the batteries. I noticed on the YDS that when I turned the key the voltage dropped precipitously. I opened up the batteries to look at the water level and it was quite low. I have them on a charger and will get them tested tomorrow after they are "fully" charged. I may need to have an internet transaction with
@ChargerGuy once this gets all squared away. Worst case is that the boat will go see a highly recommended mechanic on either Sunday or Monday.
It's a bummer from a timing perspective as I had promised to take a couple young families out for some fun tomorrow afternoon - the one guy is a banker and takes me golfing on the bank's dime.
