SOLD SOLD JENSEN Marine AM/FM/USB/Bluetooth Waterproof Stereo with App Control
kthrash
Madison, MS
If you are looking for the latest advancements in boating entertainment than look no further than the new MS2A AM/FM/USB/Bluetooth waterproof stereo with app control! This 160 watt stereo features a modern design and Bluetooth interface capabilities with A2DP/AVRCP technology as well as app control techology allowing users to control all of the primary functions of their stereo from their mobile device. The unit also has a rear auxiliary input along with a USB input. In addition, the low battery alert and zero current memory draw will keep you informed at all times. The MS2A was built specifically for the marine environment by featuring a solid top chassis, UV resistant materials and a corrosion resistant finish.
Visit your iTunes or Google Play store to download the jControl app.
  • 12V DC power system (2-wire)
  • 1 DIN panel mount chassis (mounting screws not included)
  • Waterproof (IPx5) fixed front panel
  • Non-volatile memory: For station presets, audio settings and setup menu option settings.
  • Segmented LCD with white LED backlighting
  • Electronic AM/FM tuner (US/Euro selectable)
  • USB 2.0 (MP3 and WMA audio playback)
  • iPod/ iPhone Ready (via USB)
  • Receives Bluetooth audio (A2DP) and controls (AVRCP) from BT enabled source
  • APP ready (jControl)
  • Rear AUX In : (RCA)
  • Pre-amp out: rear channel only (RCA)
  • Wired remote ready compatible with MWR75, MWR100 and MWR150
  • Beep tone confirmation (user selectable Off/Beep/Click)
  • EQ presets (Flat, Rock, Pop, Classical, User settings)
  • Conformal coated PCB
  • UV Resistant: ASTMD4329 compliant
  • Corrosion resistant material/ finishing ASTMB117 compliant
  • Low nattery warning: audible over audio output and visual on displays when battery voltage is <10.8V.
  • Uses ISO 10487 locking connector for power/ speaker
  • Regulatory certifications: FCC, CE, RoHS, UL60065
Slightly used out of a 2017 190FSH, works great, everything needed to hook up included, wiring harness, and usb/aux cord. Asking $75 shipped.
njmr2fan
Augusta GA
Send me your PayPal, I'll take it. It's the white and black faced one right? Pics not coming through by phone.
kthrash
Madison, MS
Pm sent
kthrash
Madison, MS
Look up jensen ms2a for pic, its black/silver
Austin1
would this fit a 2009 sx210?
kthrash
Madison, MS
it fits in a standard DIN cutout so it should.
kthrash
Madison, MS
SOLD
Top Bottom
