Some weekend updates to the FSH.
kthrash
Madison, MS
Installed a few things on the FSH this weekend..
Hose Holder ($13 Stainless Steel paper towel holder from Amazon) https://www.amazon.com/gp/product/B001AOK8SE/ref=oh_aui_detailpage_o04_s01?ie=UTF8&psc=1
Garmin 73DV GPS/Fishfinder
Standard Horizon GX1700GPS VHF
Pacific Aerials Antenna Mount
Inside Rod Holder
NOCO Genius Battery Charger and Charging Port with splitter for additional charger later in front
McMaster Carr Sticker Rulers
Shallow Water anchor holder (D-Rings)
All great ideas. I really like tbe inside rod holders and tbe hose attachment.
Hi
Also, did you mount your battery charger in the battery compartment under the jump seat? I put mine there but i am worried about venting it when its plugged in. Also what is the orange extension cord for?
Hi
I mounted the charger in the storage area under the rear seat. The orange extension cord is plugged into a port added to the side of the helm to power the existing battery charger I installed and a second one I intend to install in the bow when I get my trolling motor setup. I simply open the battery compartment when charging the batteries.
Thanks for sharing!
Some great ideas there.
kudos
I've been afraid to mount anything w the assumption is m going to change my mind.
Looking really good! I have my Garmin 741sx mounted in the dash like yours. Same radio and antenna in the same spot as well. Great idea with the washdown hose.
Good ideas. Well executed. I'm making an anchor pole holder out of a PVC elbow and some starboard I had. I'll post it when it's done. Like the battery charger hookup. For now I'm just using alligator clamps and a battery tender but would like the permanency of what you did.
