Spark plug condition
FLJetBoater
Helping a friend out with an oil change on a boat…(2016 242) he bought it with 30 hours and now has 190. Oil/plugs were changed by previous owner before purchase and he saw the invoice. When we removed them I barely had to put any pressure at all (like I didn’t think the spark socket was on the spark plug type of loose) I probably could have removed them by hand. Boat was running fine but they look really dark to me even for 160 hours.
also not sure if it’s recommended but looks like the dealer greased the boots which made them easy to get out but also made a bit of a mess in the tubes for the plugs.
Babin Farms
Lower Alabama
I'd rather have dark plugs that plugs that are too light in color. Does your friend ever open it up and go or mainly just put around?? I would think that everything is ok right now if it was running good to begin with. There's a lot of times I pull plugs on any engine and they'll seem loose but the last thing you want to do is overtighten spark plugs. Greasing (dielectric grease)the inside of the boots definitely helps in getting them off the plugs.
FLJetBoater
They do open it up but around here unless the conditions are really good it’s usually 6k rpms (30mph) or less…..
thanks for the info!
Mike Clark
Germantown, ohio
I think the most people are changing them at least once every year or 40-50 hours?
FLJetBoater
I believe it’s once a year or 100 hours. These are about 130 hours but also only 6 months old.
David Martin
Punta Gorda
Hard to see the ceramic insulator inside the plug what little peak I can see on 2 of them look ok, I'm with Babin you do not want to see vary vary light tan lean burn no good.
My plugs at 23 hours of use(7 years) 2013 were medium to dark brown insulator with Black electrodes and Black carbon build up around plugs combustion rim. This also checks out to what owner said about his 7 year 23 clock hour ownership/use he and his wife(mid 70's age) just idled around the lake so they traded her in on a pontoon.
After 6 months under my ownership I'm at 100 hours now, and getting ready to pull the plugs for a read.
