Speedometer not working on my 2021 yamaha SX210.
Relaxsingh
Miami
Hi,
Can anyone share some info on where the speedometer tube is on my sx210. My stopped working today. How do I check it.
Hi,
Hi I have a sx190. My speedometer is on the bottom rear right of hull. It acts as a spinning wheel. I once ran aground and the plastic wheel bent causing the speedometer to stop working. Once I straighten the wheel out it worked fine. I hope / think we are talking about the same thing.
Hi, thank you for the reply. I will check and see if my is in the same location.
Hi, I checked for the wheel under my boat. I found it. It was jammed with sand or weeds . I got it loose again, it's spinning freely. Hopefully that was it and it will work.
Thanks for your help
Good. I’m sure that was the issue. Let me know. Glad I could help. ????
