pumper
- Other
- Other
We just picked up a 2000 Cutter 17ft with merc sportjet 175 jet drive. owner says the engine stopped on him this past summer after running it at low rpms through a river followed by WOT. Flywheel turns smoothly with socket and bar not quite full rotation ( 280 degrees) either way and does not feel like anything dragging..just stops. Before pulling the engine, does anyone have any ideas of the cause or troubleshoot cause other than major interior engine failure. i.e pump/ gear /impeller issue. Thanks
