Nikokrzynowek
- Connecticut
Backstory quick. I got this boat with the starboard engine completly seized up, never started it. Port engine ran just a ton of water in the oil. Rebuilt both engines got them in and running yesterday, just a quick start up they ran I shut them down. Went outside today to do a quick start up prior to taking them out to break in the engines and the port engine fired right up idled perfect no issues at all. Starboard engine tho fired right up then immediately stalled. Tried to crank it over quite a few times before it fired. Once it stared up it was idling really rough. Honestly sounded like the crank was going to fall out of the engine. Attached is a quick video of the engine running. I’m hoping someone on this form has had the same issue with their motor before and an easy fix. I’m leaning towards maybe a bad coil? And the engine is just misfiring or possibly injector. Any help would be appreciated. Thanks guy!
