Kernel
- Corpus Christi, TX
Just want to run this by the peanut gallery before I drop money on a new starter and pull the header to replace it.
2017 AR240, 185 hours, zero issues to date. I’ve done all my own maintenance as per the recommended schedule using Yamaha products. I’ve got the extended warranty, but the closest dealer is a good 2.5 hour drive and I don’t feel like being without the boat for as long as it would take them to get around to fixing it in the middle of the season.
Both engines started fine on Sunday when I put it in the water. Spent the day at the beach, getting ready to head home the port engine started fine, went to start the starboard and immediately knew something was off. Getting 250-300ish RPM during the crank, it turns over a good 3-4 times slower than the good engine. I want to say the port is 950-1200 RPM on crank and fires straight up. Let it turn over a good 5-6 times with no joy. Waited a bit, tried again, no joy. Checked the impeller clean out port, clear. Put on the goggles and got under the boat, clear. Decided to limp home and see how it would do out of the water.
Since putting it on the trailer I’ve checked the air filter and plugs, all appear to be in very good condition. No evidence of oil or water in the air box. Cranked the engine with all four plugs and air filter removed, issue persisted. Did note that the plugs were wet when compared to the plugs from the good engine. Smells like fuel. It does look a bit dirty down in the spark plug holes, but about the same as the good engine and I am no mechanic, so I have no idea how “clean” it should look.
Checked for corrosion at the battery, grounds, and connections to the starter, all appear very clean and free of corrosion. Checked the volts coming from the relay while cranking with the kill switch pulled and it matches the good engine. Getting a max reading of about 8.5v from each, which seems a bit low, but I’m not great with a multimeter and since it matches the good engine I figure it means everything from the battery to the relay output checks out. Also swapped the relays, issue persisted on the starboard engine.
Removed the pump housing and impeller to check for binding. None noted and the engine still cranks slow with the impeller and housing removed.
Best guess is that the starter is bad and can’t produce enough torque to turn the engine fast enough to light off. 200ish hours and 4 years seems like a reasonable amount to expect from a starter I suppose. Though we don’t necessarily turn the thing off and on all that much. Kiddos are still too young for wake sports, so we mostly go to and from the beach/sand bar and look for dolphins, [HASH=6003]#girldad[/HASH]. Thoughts?
