jetboater4life
- Rochester, MN 55901
- X
I searched through the forum and faq and could not find any thread discussing a similar problem so here goes. We did about 30mins surfing with a few quick stop and starts as we switched riders. After the last rider was done I turned off both engines and to my surprise the starter on the port engine started cranking over the engine (or possibly was cranking the entire time the engine was on?). I switched off my dual battery switch to cut all power and it stopped. Then I turned the switch back on everything was quiet, the starter did not start cranking the engine. I then started both engines and they fired up just fine. Turning them off led to the same behavior with the port starter just cranking the engine.
It was towards the end of the day with mosquitoes (northern MN lake) and a thunderstorm inbound so I closed it up and put the cover on it while it sat tied to my parents dock.
Here is the problem. I need to get it on the trailer (about a 25min boat ride at 30mph to the launch) tomorrow so I can head home. I could debug the wiring and inspect ignition switches and battery connections but I am concerned that if I break something then I am really stuck. Could this be the starter solenoid/relay or something with the starter?
Like I said before, in all the posts I reviewed it was about a starter not cranking where I have the opposite. A little more searching on car forums gave me some other clues but unlikely to be simple fix so I think I will tackle it when I get home.
Please share your thoughts and opinions. This forum has kept my boat out of the shop for all 12 years of ownership.
2010 212x MR1 engines
