- Royal, AR
- SX
Sunday evening I had the unfortunate experience of breaking a steering cable.
I felt the pop in the steering wheel when it happened. At speed I noticed I had less cornering to the right. But I anchored and backed toward the shore at two locations while traveling perhaps 10 miles without an issue.
When we headed back to the ramp I discovered that I could not turn right. I barely managed to dock while @Rana and the kids made circles. They barely managed to make it back to the dock. I then proceeded to make four or five circles to the left as I tried to figure out how to get the boat to go straight.
Eventually I determined that the port steering cable was broken and that if I powered down the port engine I could steer when running on the starboard engine alone. I was able to put the boat onto the trailer but needed to restart the port engine to get her fully loaded.
Once out of the water I found that turning left the broken cable would push the port jet to the left but it would not retract it when turning right. I believe that when running at speed the force of the thrust was centering the jet allowing the boat to run straight.
I hope this never happens to you but if it does it may help you navigate your boat back home.
