ndwiginton
- Muscle Shoals, AL
- Limited S
Is that with both battery switches on as well? If so that is not something that should happen.
The reason both battery switches need to be on is that the start battery is supplying the red ignition switch wires with power. When the key is turned to on the +12v signal from the the start battery is what makes the accessory power turn on.
No that is with only the House battery switch On and the Starter switch OFF
