steined
- Newport, Kentucky
- Limited S
I ran 4 ga marine wire directly to a Fuse block terminal similar to yours, only I didn't run the amp through the battery switch: http://www.amazon.com/Blue-Sea-Syst...00292746&sr=8-13&keywords=fuse+block+terminal
1.) The 8 speakers would be running at 2 ohms, which it can do. Nothing special there
2.) 2 ways. My head unit has 2 preamp outputs. I used each output and set my "base level" via the gain for the front and rear channels. I set my front to be slightly less than my rear. On my boat the front is the bow and tower tweeters (which I'll likely replace with cabin 6.5" eventually). Then if I need more adjustment I use the fader. It isn't simple to do, but it can be done. I wish I had more control, but I am fine with this limitation in light of the cost to get full zone control and more amp channels.
3.) Most people would probably be against it, but I mounted my amp to the base of the dash area using 4 full length strips of industrial velcro. When I was installing my sub I found out how strong that stuff actually is. It took more time to un stick the amp than it did to wire it up! It gets hot there, but I think it would get hot anywhere and I haven't had it go into protection yet. It sits at about a 30 degree angle if I had to guess.
