Structural damage? 2018 242 limited e serie
Rickytrz
242 Limited E-Series
I would like to know what is happening here, is the door shrinking or the boat is getting wider? Somebody knows how to call this kind of damage?20220820_111405.jpgScreenshot_20220822-093450_Gallery.jpg
adrianp89
Tampa Bay, FL
252SE
Was it normal in the past? This just looks like Yamaha quality boat.
Rickytrz
adrianp89
Tampa Bay, FL
252SE
Probably just the panel shrunk. I don't see any chance of structural damage.
jmargo
Check the seams on the left and right side around the storage compartments and ski locker. If the boat has moved you should see cracks in the gel coat.
Rickytrz
Ok I will check thanks
Rickytrz
Something else, two years ago the dealership had to adjust the windshield this happened and I think helm and the storage side are getting separate.
adrianp89
Tampa Bay, FL
252SE
There would pretty obvious signs on separation in the boat. Look under front seats and rear seats. If need be, take off beauty panels in head.
tdonoughue
The Woodlands, TX 77381
I agree--there must be other evidence of what is happening here. I have never heard of a windshield being 'adjusted' because it fell through like that. And now the doors?
I would check the ski locker first & see if there is anything evident there, as it is right below where you are seeing the issue. Then I would start going forward and aft of there, checking joints, looking for cracks.
This is weird.
Rickytrz
This is weird.
Yep definitely this boat is weird cuz I been experiencing odd things that nobody has ever seen.
Rickytrz
I was hoping there is room to make adjustment in the other side, looks like it never moved and install is flush.
Oh no it seat flush in the right side and no way to adjust, looks like the storage side was the side that moved.
HawaiiBreeze
Oahu Hawaii
You now have photo evidence which you can compare from time to time to make observations.
Rickytrz
An update on this thread, dropped the boat at the dealership in Sept 2022, Dec 2022 people from yamaha factory found cracks on some glues inside the boat so the boat went to yamaha factory for repair around end of January and beginning of February 2023, so March 2023 factory brought the boat back to the dealership and this is the condition of the boat that #Yamaha factory left it after fixing some structural damage.
jmargo
You left it at the dealer to get detailed and final tweaks ?
Rickytrz
Still there are many things that they need to fix on it.
buckbuck
Texas
Help me understand. You entrusted your boat to Yamaha and thats the way they returned it? Can I assume that it was clean when you gave it to them?
