Subwoofer Location
Devildog
Chain O' Lakes, IL
I looked at a bunch of the old postings, but did not see any on storing a subwoofer in the storage locker in front of the helm. I have a 10” enclosed subwoofer that I was planning to put in this locker, but was wondering if you guys had any feedback on whether this was a good idea.
tdonoughue
The Woodlands, TX 77381
I think it depends on your porting plan. Bass is omnidirectional, but that doesn't mean it goes through walls very well. You would need a grill or something in the door, next to it, or on the kickplate below the helm. I wouldn't do below the helm (I would wind up kicking it in). And the door is doubled over, which may cause complexity...
So, not impossible by any means, but it would depend (IMHO) on how you were going to port it.
Noko
Lake Nokomis Wis
If you are going to have a speaker cover over the sub, check that the cover mounts flush before you cut the hole. Someone else here had to do some extra finishing to fill in the gap between the cover and the side where the sub was mounted.
Devildog
Chain O' Lakes, IL
I’m not planning to cut the subwoofer into the fiberglass. The subwoofer is in an enclosure and the enclosure has legs which allows it to be placed on the floor in the locker. The subwoofer itself would be directed toward the floor if I end up doing it this way. I was just wondering about vibrations in the locker and the folding door. The good thing is that I can try it before securing it, but just wanted to get any initial thoughts as I wait for my purchase to arrive in the mail.
Huntersales
Indiana
I made a custom ported box and put a Rockford 12" sub in there last season. You will have vibrations( my whole helm rattled when it was hitting hard) and it will be a bit muffled, but it is doable. I have since moved it back under the starboard side bench seat with a 10" vent cut where my initial IB sub was. Much louder. Still fighting some rattles!
JTC1016
Spring Lake, MI
I have my 10" enclosed sub in that location. It is fine for me. I think it sounds great. Sometimes if we are anchored I open the door but I haven't really found that to be necessary.
Devildog
Chain O' Lakes, IL
Yeah, I was a little worried about the vibrations. My wife is not a huge bass person, so I am in the dog house even before the thing is installed. So I don’t have much to lose:).
I would be concerned about subjecting all of the electronics in the helm to constant vibrations caused by the sub woofer, especially if I had a boat with a connext system. I know it is all solid state marine grade but even if the electronics are not damaged bass vibrations have a way of loosening things, like mounting nuts and bolts up.
Milligsc
Can you share how you vented the sub? I have a 10 inch skar sub in a box in starboard seat also. It sounds good with the seat down but great with the seat up a few inches. I was thinking of a vent but not sure how big it needs to be.
Milligsc
jEt_jAk
SoCal
AR195
Yea. Same as opening the storage vs closed.
white2kstang
Austin Texas Area
I put it in the rear starboard and cut a speaker vent.
I tried a couple locations with this same sub. Helm rattled too much and acoustically it sounded better in the rear storage so that's where it stayed. I did not cut a port hole for it though. I have not found the need yet and I could still add 100-150w of power to boost it if needed. Even propping the seat an inch only made a slight difference.
Milligsc
Can you tell me where you bought the grille? I like that style.
