SuperCharger clutch replacement ( rebuild )
DJMattyT
Long Island, NY
Same, I have 70hrs and supercharger is great but I will be doing the rebuild at 200 hours. My jetski dealer (not Marinemax) says all watercraft and marine supercharges have a life expectancy of max 200 hrs. Some may run a lot longer but 200 is the time to rebuild. I will be upgrading my supercharger at 200 for a little more power too :winkingthumbsup"
veedubtek
Punta Gorda, FL
Scout
Ditto on above. My Doo is at 91? hours now, and 4 years old, on the original chargers. Hasn't lost a bit of top end or performance. I may rebuild them to help with the sale if I still have it this winter, but even as obsessive as I am about maintenance, I just can't justify it right now. 200 hours is a definite, and I imagine you'll notice less top end at that point. 2 years? I don't buy into that so much, but to each their own.
Rtimleck
Springwater, Ontario
Scarab
HO Impulse
What kind of upgrades are out there for superchargers? Haven't exactly looked into it but you've peaked my curiosity!
Scarabtech
Michigan
Scarab
Allright here's the what you should do regarding your supercharger maintenance. At 200 hrs. you need to have it rebuilt. This is at 200 hrs no matter if it takes 4-5 years to reach 200 hrs as it can in Michigan. When they used ceramic washers back in the day it was every 100 hrs. The labor bto have this job done should not exceed 3-3.5 hrs of labor. Unfortunately somebody in this post hit the nail on the head when you said untrained mechanics. However you see this with all brands and styles. Research your dealer before buying.
ScarabMike
Green Cove Springs, FL
If they would research the dealer network, then there would be way less Scarabs sold. 90% of the "dealer network" is flawed, and looks at Scarab customers as a nuisance. If Scarab would have thought about post-sale relationships with their customers, they would have contracted existing SeaDoo dealerships to sell and service their boats. Not a direct competitor. Its amazing how the Scarab line is the only one of the new Rotax powered boat lines that are having the majority of the issues. The Chaparral has been almost flawless in their launch, quality, and post sale experiences.
Speedling
Cedar Lake, IN
SS
And THIS is what will seperate the lines from each other.
Yan Masse
Trois-Rivieres, QC, Canada
Scarab
HO Impulse
My dealer is one of the biggest BRP dealer in the area, it may save my ass sometime.
Janguh Lang
SW Detroit
Scarab
HO Impulse
ACE supercharger? Maintenance free! Im onboard. Anyone have any links to info on them?
Thanks
.... Or wait til the warranty ends, and replace the old SC with the new ACE one, its maintenance free!!!
I have close to 70 hours on my boat and the supercharger is fine for two years of use.
What are the economics / financials on maintaining v. upgrading the supercharger?
I've always wished Yamaha would put superchargers in the 240 series boats but only the 192s have them. I wonder how often they have to be rebuilt and at what cost?
Only the 192s are supercharged as far as I know.
Speed_Freak_039A
Scarab
HO Impulse
Thanks
You have to change the whole back pto housing to the new style to be able to run the new 300hp superchargers.
Also none of them are maintenance free. Don't believe that claim. Clutches are a wear item.
R502
Scarab
HO Impulse
Everything I've read here or by the manufacturer would lead me to pull the unit and have the clutch replaced after two years despite the hours. I'll have 90 or so hours by the end of this season (28 months) and plan on having the clutch done for peace of mind.
ScarabMike
While the wet clutch rings do wear, the supercharger maintenance on the Rotax superchargers is for the bearings. The new superchargers are built with bigger forged, and forged internals, the oiling jets are bigger, and the cogs have been built with larger splines.
I'll elaborate on "Maintenance Free". It's maintenance free FOR THE LIFE OF THE WARRANTY. But, still better than the second gen units we have on our Scarab's.
Also, looks that its not backward compatible with the 1503. So that sucks.
As far as rebuilding the SC. You can do this yourself if you have proper tools. Or there are companies you can send them off to. These two options are way cheaper than the dealers.
Speedling
Cedar Lake, IN
SS
I still say turbo. Modern turbos don't have to do the rebuild nearly as often and don't have the stresses of a belt or chain drive on them. Would need to figure out the drain system for the oil but not a problem there as there are kits out there for these conversions.
Just gotta worry about heat!
Pretty sure you could have the dealer rebuild the supercharger a good number of times before the turbo kit starts to make any sense. I mean, it'll burn more gas with the extra boost too so probably not saving any money. Could get a boost controller and tone it down for gas savings and then turn it up for playing around.
Speedling
Cedar Lake, IN
SS
A turbo jet boat @Speedling ....... Sounds like something you and I should accomplish,lol.
Like i said, there are kits for the supercharged motors from both sides. Not the mr-1 as they never were able to crack the code from Yamaha. I have other projects on my hands or i would be totally into it! Maybe once my kids are a few more years? We decided we want to see if our kids are into cruising and sightseeing, wake sports, speed, or just swimming. That will determine a new boat and new mods.
Speedling
Cedar Lake, IN
SS
Top Bottom
