anmut
- 212S
Unfortunately the out-of-box setup is pretty lame for wave creation when it comes to ballast. Yamaha, like Chaparral, doesn't understand that weight=better wave. To get the best way you'll need to add some more weight. If you're not trailering a lot, you might consider using lead bags that will store in your aft compartments. You'll just have to transfer them to the surf side.
As others have said, it's about putting that platform slightly in the water and getting that lean going. For now, i would keep your surf-side tank at 50% full and get all passengers to sit on that side.
