Ozark
- 195S
I see aftermarket catch cans recommended over and over for the SVHO engines. The SVHO (at least the 2020+) has a factory installed oil separator AKA catch can. Is the factory installed oil separator inadequate at performing its job?
The only difference I see in the factory installed oil separator and an aftermarket catch can is where the "separated" oil ends up. The factory oil separator returns the "separated" oil to the oil pan, whereas the aftermarket catch can keeps it stored separate for disposal. If the goal was to prevent the "separated" oil from returning to the oil pan via the factory oil separator, then the aftermarket catch can would need to be installed upstream of the factory oil separator. Everyone seems to be installing the aftermarket catch cans downstream of the factory oil separator, so I don't believe that is the goal.
It seems that adding an aftermarket catch can in this application provides no benefit, only an extra point of failure or potential pushback from the dealer on warranty work due to emissions alteration.
I am all for prolonging the life of my engine, especially with relatively easy mods. I am hoping someone can explain to me the benefit of an aftermarket catch can for this specific application.
The factory oil separator I am referring to is #5 in the attached diagram, pulled directly from a 2020-2021 195S Service Manual.
