Drift Away
- SX
Thanks. Its tilted maybe a 1/4 inch but i can live with it.Looks like you did a real nice job.
You probably won't even notice when you are floating.Thanks. Its tilted maybe a 1/4 inch but i can live with it.
Yamaha covered it under warranty and instead of having the dealer put it in I put it in myself.Where did you find the replacement radio at?
When i took it in for service they reached out and for some reason they covered it again.I though they would not cover that radio? How did you get them to cover it? Think mine is about to go.
Man, that looks good. I’ve been meaning to do this forever, how does the table mount fit? Any issues? Just bought a new part, correct?So i have replaced my swim deck radio 3 times now. But this time i did not put it back in the same spot. Its a little tight and ill have to trim the rubber cover (i almost never use it anyway) but this is the best spot i could find to keep it out of the water.
View attachment 92100View attachment 92101View attachment 92103View attachment 92104View attachment 92105View attachment 92106
The table leg covers the hole. But i did have to put a piece aluminum at the bottom behind it with 2 holes. The top holes are into the boat the bottom is thru the plate. Nothing to rewire. Its just a S video looking cable that plugs right in. They gave me a whole new radio. What we see on the swim deck is just the remote. The brain is under the dash up front. I did not change that out so all my presets, bluetooth ect are saved.Man, that looks good. I’ve been meaning to do this forever, how does the table mount fit? Any issues? Just bought a new part, correct?
Love it!!
Was there a need to rewire the remote or did you have enough slack on the factory wire?
Prefect
I am not 100% sure our table legs will fit. Ill be back in FL 9 may and i can let you know for sure. I have never used my table on the swim deck it just sounded like a good way to cover up the whole.Prefect
Thanks
While I was adding that item to my “boat list” on amazon, I also saw the whole kit with mount, leg, and table top. With the kids, I’ve always thought it would be handy to have a 2nd table located in the bow.I am not 100% sure our table legs will fit. Ill be back in FL 9 may and i can let you know for sure. I have never used my table on the swim deck it just sounded like a good way to cover up the whole.
Hahaha thanksI am not 100% sure our table legs will fit. Ill be back in FL 9 may and i can let you know for sure. I have never used my table on the swim deck it just sounded like a good way to cover up the whole.
