Switch for underwater light
Mike Byrd
I am thinking of buying the Trinity Transom underwater light for my 212X. It puts out 24000 lumens. I would like to add a switch that matches my other Yamaha boat switches to turn it on. I was thinking of mounting it under the speedometer. Does anyone have any specs on these stock Yamaha switches? Will these switches handle this 24000 lumen underwater light?
haknslash
Lake Martin, AL
Moomba
They are just your run of the mill marine rocker switches and are not Yamaha-specific. I see them even in auto parts stores like Advanced Auto and Autozone. Some of them come with their own switch marking labels.
giroux68
Cumming, Georgia
I want to see what those look like in the water! On my list of mods. BUT with a big guarded switch like a self destruct style.
njmr2fan
Augusta GA
Wow! What a light! Where'd you get it, and do you have any photo or videos of it?
Pinhacker71
Verona, KY
242 Limited E-Series
Just get the WiFi controller. I use it for my 8000 lumen light. Works great. I’m contemplating removing the one light and replacing it with this one for triple the lumens.
Mike Byrd
Thanks for all the responses. I have used OTRATTW before for my Polaris side by side switches. They work great, but it looks like they are a little different style than the stock Yamaha switches. I am not opposed to buying one of the stock switches from Yamaha, but at $40 a piece I want to be sure it will handle this light. I am not an electrical guy, so do I need relays or can I just directly hook up this light to the switch and go? Boatpluglight does have a cheap ($12) controller with a remote, but the thought have having to keep track of one more remote is not something I want to do unless that is my only choice.
Mike Byrd
I sent the company an email about using this transom light with the switch from OTRATTW. I will let you know their response.
Honey Badger
Georgetown, TX
Most of the higher quality products will include a wiring harness with a switch and an inline fuse to make it easy. You will want a fuse somewhere along the line to protect yourself. For the jeep I use an spod. It looks like a lot of these guys use a blue sea fuse block. Max is 30 amp fuses, but that should be plenty for your lights since they're led. Hope that helps.
Mike Byrd
I heard back from boatpluglight. They said the OTRATTW switch would work fine without a relay. The also recommended a 15 amp fuse be used within 18" of the power source.
Honey Badger
Georgetown, TX
Awesome. Can't wait to see the install. That's definitely on the list after I finish all my safety and make life easier mods.
Jebinok
Conway AR 72034
Mike Courterier
@Mike Byrd be careful making the switch too accessible and easy to turn on... the light requires water for cooling and if it accidently gets turned on when your boat is on the trailer it will quickly die.
I hid my switch in the battery compartment and also bought their remote, so the switch needs to be turned on and the remote needs to turn the light on, so I have double protection.
njmr2fan
Augusta GA
I need this.
njmr2fan
Augusta GA
Mount it to a piezo buzzer and a strobe light.
Mainah
Chapin, SC
Hmmmm. I currently have no way or knowing when my keg is low. If I can figure out a sensor that would not give off false positives I could hook that up to a buzzer with the switch on and shut it off unitl I swap it. Perhaps a strain gauge under the keg hooked up to a controller to take an average reading over time could work to prevent false positves from bouncing up and down. I really don’t need another project right now though.
