Matthew Sawicki
- Minneapolis
- SX
Happy 4th everyone!!I have an issue and can't find answers.
I've called my dealer but haven't heard back and not a fan of them.
My port engine maxes at at 5,000 RPM even at full throttle. This last trip after sitting all day and listening to music my battery died, bt I had a spare and jumper cables to crank it (can't be too cautious) . The check engine light came on as well and gives the infamous code YDIS -1 which I can not find anywhere.
Last year this happened and the deal said it was in the inboard propeller that was damaged and not providing the thrust which caused the engine to over heat. I checked the propellers and they are in excellent condition. I picked the boat up from the same dealer I used to winterize and do a spring start up. from the first outing I had no power and some smoke from the port engine. I assumed it was excess oil burn off from a sloppy oil change.
My Questions are:
1- Has anyone had the lack of power issue in one of the engines and if so what did you do to fix it? (all propellers are cleared and intakes cleaned out)
2 - Anyone know what the YDIS 1 code is for Check engine light?
Appreciate all the help
My Questions are:
