2017 SX190 - Communication error occurred between the PC and ECM
jesssejamesss
SX195
Communication error occurred between the PC and ECM.
Red light on cable turns red when I bump engine, then turns off.
Get same error if I leave the engine running.
Using YDIS cables from Amazon, connect well, using YDIS v1.33.
Installed software using Admin.
Com port = 1
Bumped the engine.
Do I have to use Yamaha proprietary cables and software?
Keep getting false engine alarms wanna clear any codes.
Any suggestions?
You have the wrong version of yds for your year boat. 1.33 is for boats prior to 2013.
I have the Service Manual for 2016-2018 SX190 (LIT-18616-rx-01).
Front of the manual says to use YDIS v1.33.
Back of manual says to use YDIS v2.00.
Thanks. The Amazon sites say v1.33 are good for up to 2017. Just gonna try to find v2.00 or higher.
That statement is not correct. Here is a screenshot from 2017.
I did not buy from this seller.
Look for one of these.
It may not have the cables for a Yamaha.
