blacksapphirez
- Charleston, SC
- SX195
I have a 2016 SX240 and had the same issue until I went in for my 10 hour service and they adjusted the cables. Can't tell what year your boat is but you may just have a stretched cable or they just need adjusted.
Ohh i did not catch that part of the post. from what I understand that will absolutely change the RPM range.I tried to adjust but there was no room for the throttle body to go any further without hitting the stop.
Your boat should have same pitched impeller on both engines which would make sense to have same RPM but mine is pitched differently from the factory which "may" explain the difference... and its only 150rpm...
Most of the new (2015-current) 240s will spin the port side faster because Yamaha stopped using impellers with different pitches (probably cost saving). Above is an explanation why.I've only recently noticed a differance with rpm wot, port being the higher. I use the boat mainly with family aboard and very rarely hold wot but did a last mile dash home the other day on glass flat water and it was there, however as soon as the revs drop the engines come back into line. Prop pitch explains this but I didn't know they are different, kinda strange.
I'm always keeping the revs synced but the starboard engine always creeps up over the port so more wot is obviously needed.
