If you have time at some point pull a tape on it, curious if I buy a pair will they fit in a toy hauler trailer. Since I can't tow my boat with it thought we would get a set if ski's if they fit
Mine is 98 inches wide at the widest part with about 6 inches between them.
Now that is with an EX and FZS.
Different skis have different widths. My trailer is an aluminum Triton
My trailer fits through a standard single garage door with a few inches on each side. So I’d call it 92”. It’s 2.5Hrs away otherwise I’d measure it for you.
On a toy hauler you should be able to stick them or put them st a 45 degree angle. You could build bunks at different level, so the short answer is that they will fit as long as you committed to make it happen
Cool thank you for all the replies, it really helps. Prob going to just be a set of Yamaha EX. Just for the wife and I to travel around. And be able to get in the water. Thanks again
