 - Lake Ray Roberts, Texas
 - Boatless
 - NA
 - Other
 - NA
In rereading this thread and considering all that a few have had to go through to get these things out, I wanted to offer a few other thoughts.  I am assuming that the that the "steel ring" that @upperdeck mentions that is glassed into the face of the fuel tank floor hatch is actually aluminum, and the bolts are stainless steel.  It is common for a type of galvanic corrosion to set up between stainless and aluminum, and I expect that is the white powder or residue on the bolts helping to freeze them in place.  The other side of the equation is having a good "bite" with the tool to remove them.  I suspect that Yamaha shifted from phillips early on to the square drive heads to try to eliminate much of this.  The problem is that a fastener of that size binding will almost prevent anything from removing it without wallowing the head of the fastener.  I would suggest using an impact wrench to help remove the frozen bolts but by the time you know they are frozen, the head is probably already wallowed out some.
