jcyamahariders wife
- Rosebud, MO
- 242X E-Series
On a Yamaha you have to list the boat to the surf side to get a good wave, doing a flap all the way across is not necessary because you couldn't switch sides to surf the opposite wake.Don' want to muddy the water, but could you build a non collpsible wedge that bracketed into both sides of ladder and went into both the tow rings.. one large wedge to clean wake on easch side same time.
I' sure you have thought of it and I'm not sure it' possible but without use of ladder folding out maybe?
Keep in mind that this is just in prototype phase and we need months of stress testing to actually see if it is going to work or not. I do not want to put something out there that is going to break. I have told everyone all along that the stress that the jet pumps put on the wedge is the #1 reason why I cannot have a flipable wedge........... While building @swatski wedge I think I have figured it out.
A universal wedge!
There will be alot more machined components so the cost will go up ( but still alot less then 2 wedges ), along with supplying 2 ladder brackets. The only thing that you will have to do is move the turn buckle to the other side of the wedge. The pins in the turn buckle will have ring clips instead of cotter pins for ease of movement. Shouldn't take anymore then 5 minutes at max. Currently running all of the parts thru the machine shop and once I have @ar240owner and my units I will post pics.
We will still be selling the single sided version so if you do not need to flip sides then I wouldn't wait to purchase.
I am so glad to see you do this!
No still only one side, just able to switch the wedge to the other side in 5 minutes max.@jcyamaharider
Are you knocking down the jet blast from both?
Forgive me if this is a dumb question, but can moving the wedge from one side to the other be done out of the water? If not would i be able to back into a shallow area and switch side?
Obviously it would be a pain to have to get on the trailer to switch sides.
We are going to start wake surfing this year, I have my daughter excited to try it, just picked up a new board and tow line. From my reading I WILL need additional ballast, which I'll eventually get, and I will also want some sort of device to clean up my wake. I'm very interested in this new product!
As of right now we will not have a flap but I have an idea on making it work with the ladder. I just need to prove the concept.So with this new design, are you going to be able to use the ladder with it attached? Will there still be the piece to swing out of the way in order to drop down the ladder? Thanks @jcyamaharider for all your work on this stuff!!
