- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
I found a small dime sized hole in a corner on the transom. It had a void between the gelcoat and the fiberglass. It chipped away pretty easy if I messed with it. It would be covered under a new purchase and dealer warranty I am sure, but they would keep it a good while. Anyway, I just repaired it pretty quick a la @Glassman instructions.
I didn't want to chip it away to find out how far the void went in each direction. It was up under the starboard ride plate on the starboard corner. Glassman suggested I blow it out with compressed air to remove any moisture, I did and there was none.
Then squirt acetone into it to clean it out and discover how far back in each direction it went. I did, and it didn't go more than an inch in either direction. It actually flaked off more when I hit it with compressed air.
After the acetone, mix up your West system 105 and 205. And have Colloidial Silica handy to use as a thickener. I also had a supply of epoxy tints that I use in the wood shop. So I tinted it white after mixing it in a 5 parts resin to 1 part catalyst ratio. I didn't pump it, I used our food scale and put .50 oz of resin on a paper plate, and .10 oz of catalyst and mixed. Then added the tint and mixed. Then added the silica and mixed. I had bought a couple of syringes along with the other supplies. The total at West Marine was a little less that a $C Note.
I filled the syringe, and grabbed some blue painters tape and paper towels. I filled the void as deep with the pointed syringe as it would go, and just let it ooz out. I did this on both sides in both directions. I then wiped it flush, and taped it up leaving an area to fill "proud", or actually fill beyond the hole itself. I did this so I can sand it back flush. I think this will be a permanent fix without even needing gelcoat. But if it does, I ordered a couple of patch kits of gelcoat to fix it with. I fully expect it to disappear completely after I am done. But it is in an area that you really can't see easily. I looked the boat over thoroughly before I bought it, and I didn't see it at all. It may have been covered with caulk from the seal job on the ride plate to the transom cutout.
I should be good to go after I sand and polish it...Thanks @Glassman !!!
