- Royal, AR
- SX
The factory stereo head unit in my SX230 was corroding internally so I decided to upgrade it.
I ordered a Fusion IP600G but when I started to install it I found that the factory opening for the stereo was much larger than a standard DIN stereo opening. I removed the panel above the stereo for easy access.
I contacted Will at JetBoatPilot.com with dimensions of the opening and he was able to cut a piece of HDPE to the correct size with a DIN opening. I used a drill press to drill holes to match those from the factory stereo mounting and countersink them.
Then I was able to install my new stereo.
As well as solving the issues with the factory stereo, the Fusion provided a huge upgrade in sound quality!
#SX230 #Fusion
#SX230 #Fusion
