16'FSHSport
- Naperville, IL
- FSH Sport
I have upgrades galore, but the Stoltz Ultimate Bow Stop model ULT-4 is a must. First of all it's a hair wider and it's made of polyurethane. I'm guessing about 100-110 durometer which means it's pretty stiff but giving. What it won't due is scuff your bow! The Shoreland'r like most trailers comes with a hard plastic bow "scratcher" especially at the out side edges. The OEM one is also a hair to narrow and the outside bow stop edges liked to ride the bow pretty hard.
Realize the ULT-4 is meant to fit a 4" bracket. The center bracket is smaller on our trailers so I used an edge-sander to remove 3/16"-1/4" on both sides (to keep it even) of the center piece of the stop. When reinstalling MAKE SURE the center spins freely and also make sure not to tighten the new bolt too much as you want to make sure the outside of the stop spins as well. All 3 sections need to spin freely.
My factory bow stop was not only hard like most trailers......none of the sections spun. The center had an almost 3/16" X 1/8" metal burr on the inside of the bracket that prevented it from turning and the bolt was way too tight.
For under $50 and with in less than an hour you can save your bow from scratches!
