EdAR230
I'll preface this by saying I'm a first time boat buyer and not mechanically inclined. So please forgive me in advance.
I purchased a used Yamaha AR230 (2007) last season. It had one replaced engine with a SBT motor when I bought it. It ran fine a few times eventually noticed vibration. I brought it in to my mechanic (he was the long time mechanic of the guy I bought the boat from). The motor (port side) was still under warranty. Sent it back to SBT. They replaced it. Said it had a manufacturer defect. Something to do with the cylinder block. Replacement installed. Took it out once, noticed oil leakage in engine compartment. Shut it down, called a tow. Engine blew. Total failure. Mechanic said SBT would replace but told him to check fuel injector, computer and for any water getting into the engine compartment. He checked all and all ok. He found a damaged flywheel. He replaced it. He said the flywheel probably wasn't the cause however - just damaged from replacing the motor so many times he guesses. He water tested it and said all he could find was a corroded clamp on the exhaust. He replaced it. But doesn't think that's the cause either. I'm picking the boat up today.
But I'm worried. This is the third SBT motor. I'm afraid to take it out worried it will blow again as I never got a solid answer to why this same port side SBT motor keeps blowing. I'd love some advice on what questions I should be asking my mechanic. And should I be concerned that he hasn't found a reason why these SBT motors keep blowing?
