Thortastic
- Lake Tomahawk, WI / St. Charles, IL
First time doing this, so I wanted to double-check my plan with all of you. This is also my first time posting a question, but I have read a lot that other people have posted, so thank you. I have a 2019 AR195. It currently has a fish finder installed by the previous owner, and the cable for this runs through the scupper valve. The 2019's have the scupper valve a bit higher than older models, so generally it's above the water line. The best picture I have is attached. The issue is that for this season, we are going to leave the boat in the water at our cabin all summer. So it will be in the water when no one is around, much of the time. This makes me very nervous, having the scupper valve open with a cable running through it. My thought was to install a seaview cable gland somewhere near the scupper valve, but as high as practical, and route the cable through this instead. To do this, I will need to drill a larger hole and four screw holes through the fiberglass. Does this sound like a good plan? Am I crazy for worrying about this? What does everyone think?
