VitaminSea
- Central FL
- SX
I noticed that my starboard side throttle is rather tense, taking considerable effort to shift from neutral to forward or reverse (as well as past the detent). Port side could potentially be tensor. Initial goal is to remove some tension from the port side to make it smoother to work the throttle around the dock. Secondary goal would be to add a little tension to the port side.
I was tinkering around with the “tensor” adjustment and did not noticed much of a difference (also appeared there was limited adjustment here, maybe 1 rotation).
Boat is as 2012 sx210. Should I consult the throttle drop FAQ, or could this be something else?
Thanks in advance!
Edit: For reference - turns out the issue was I was in need of replacing my bucket cable.
Utilized SeaStar CCX63318, about $50 and is the same cable as OEM
To complete both sides it took me approximately 3hrs. I did need to pull up the fuel tank cover as the existing cables were zip tied with other cable runs.
On the 210 the starboard cable was the most challenging to pull through the thru-hull fitting, due to how the cable needs to bend around the clean out port tube.
Starboard cable was split and corroded. Port side ended up not being corroded, but post replacement the throttle engagement is noticeable smoother.
Links to two write ups that assisted me.
https://jetboaters.net/threads/reverse-cable-replacement.19187/
https://jetboaters.net/threads/how-to-replace-reverse-gate-cable.28/
Thanks in advance!
