Nobody has ever replaced the crank as prevention of this issue, Now you truly are reading too far. The only ones that have replaced a crank are the ones that have had catastrophic failure after the timing chain gave out.its getting to the point i wondering if this is a project doable yourself if crank is left in ...then
The Yamaha upgrade kit actually does include a crank. There are a few guys on the Yamaha FB page that have done the work minus crank recently and if you search the green hulk forum the jet ski guys do the same.
Basically you set the timing, remove the oil pump and pump gear on the crank(reverse thread), remove tensioner, guides and cam gears. Reinstall opposite with a bunch of gaskets, o-rings and crush washers. That's the down and dirty version.
I'm curious. If 12-15 model years were the same design, why are the 14 and 15 models "anecdotally" more likely to fail than say a 12 or 13 model year? i'm a seadoo guy and have no dog in this fight, but like others, have read the posts when they come up and am wondering if someone has a rational hypothesis.....
First thing to do is take off the valve covers, mark the chain and bump it with the starter so you can inspect all the links. If you are still worried you can upgrade to the 2016 chain. You need to replace the cam sprockets and guides also. It will be a little wider on the crank but there are now a few people who have done it on their boats and a lot more jet ski guys.
any hp improvement t lol ? .. does she rev up faster or slower ?This is exactly what i did. I have a 2013 Sx190. I upgraded to 2016+ chain, guides, and cam sprockets. Put 38 hrs on that setup this year. No issues
more rotating mass, so probably slower in theory, but I bet it's not perceptible.
The additional noise from the friction of the wider chain should drown out the previous tick tock of the shorter lifetime clock ticking backwards...
(KIDDING!!!)
