tdonoughue
- The Woodlands, TX 77381
Got up to the boat today and did some work.
First, FINALLY installed the swivel rack that I bought... um, years ago. And it has been sitting in my boat taking up space. Had to figure out how to adjust the angle (I thought I would have to press the two pieces apart, but I was able to rotate them using a bar clamp to grab the tower clamp piece--that gave me enough leverage to rotate it). Then it was pretty easy--just screw it on (once I put it on upside down, then flipped it over and put it on the other side like it is supposed to be--don't ask).
Then, I finished the off-season project of redoing all of my battery cables. You may recall, I had an issue with low battery alerts. Figured out that there were loose cable connections on the ends. Then figured out that the switch was broken. So, replaced the switch, but still had issues. Wiggled some wires and figured out more cables were bad. So, fed up, I bought a proper cable termination crimper tool and proper terminators: https://smile.amazon.com/gp/product/B00MVE48Z6/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1 and https://smile.amazon.com/gp/product/B083QBQKC5/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Then I set about methodically pulling each cable. Each cable size was evaluated, the right terminator put on it (fitting the bolt on which it was connected, too). Then heat shrink installed on each. I know it is not the neatest install, but in the interest of 'pics or it didn't happen':
Still was only getting 12.something volts, while connected to the charger. And I tightened everything and everything. Unplugged the charger and re-plugged it in. Noticed that it was on gel mode. Put it back to flooded mode and the voltage started coming up to where it should be. So another victory.
I got my new Harbor Freight ammo boxes, so I pulled a number of cheaper boxes I had in there and reorganized the boat crap into the new boxes. No pics--that was boring.
Then, I got some egg crate, so I was going to install that into the engine compartment. I opened the hatch, where I had stuck some dynamat stuff to the hatch:
Being nearly as perceptive as you, I, too, noticed that there is no dynamat stuff there.
Oh, there it is. Stuck all over the top of my engines. With that black goo EVERYWHERE. You can see drips on the drain hose pretty easily. But they are everywhere. Bottom of the bilge, covers, air filter cover--everywhere. And check out the starboard engine exhaust manifold. That stuff is all over it.
I didn't have any solvent with me, so I pulled off the pieces from the engine, tossed them with disgust, and closed the whole thing up to take care of that a different day.
So, a mixed review, but more wins than losses. I will take it. Progress.
