LakeTravisBear
- Austin, TX
Second this! If you get an inflatable, get one of these. It is hands down the best to inflate deflate things and it will do several on one charge. I usually carry a spare battery as well but never end up needing it. My buddy inflates his 16' zodiac with it and it does that thing in less than 3 minutes! Might be the best thing Ryobi makes!
RYOBI ONE+ 18V Cordless High Power Inflator P738 - The Home Depot
This wonderful RYOBI ONE+ Cordless High Volume Power Inflator is perfect for fast, high volume inflating and deflating of air mattresses and pool toys.www.homedepot.com
you need a high pressure or hand pump to top off if you use this one because it does not have enough power to get the tubes to the correct psi to tow properly.
