Beachbummer
- Houston TX
- SX
So I hooked up the YDS today to check on my TPS sensor hoping I may notice something odd causing the loss of 500 or so RPM at the top on the starboard engine. Both engines had very similar values for the TPS but I was surprised that WOT values are 80 degrees and 3.82 volts. Is there anyway to set or indicate to the ECU that this is WOT? seems 78 degrees is not quite WOT although the throttle plates are actually dead open at 90 degrees.
I was hoping this number was low and could affect fuel delivery on Starboard, but port runs perfect and has the same numbers.
Anyone noticed their TPS values with the throttle fully opened and remember what it was? Any way to adjust it? I'll be looking at other possibilities to find my missing RPMs since the values are consistent across both engines and the one engine works great, but I wanted to confirm with others if possible.
Thanks!
Thanks!
