Trailer Guide-ons for AR210 Trailer
thetwb13
Just picked up my new AR210 today and was looking for a set of guide-on posts for my trailer, but the frame of the trailer is very compact at the rear end and I haven't really found any yet that look like they come out far enough to give clearance for the hull. Anybody have any recommendations?
I suggest you take a few measurements and shop online for the set that best meets you needs.
I’ve had a set like these for over ten years over two trailers. They only cost half as much back in the day but I’d buy another set at today’s price if I was in the market for a set.
PBear
Sunapee, NH
Moomba
Wake
Used the CE Smith 60” on my 2020 212X trailer - lots of adjustment for width
biffdotorg
Pelican Rapids, MN
I've owned CE's on my current trailer and VeVe guides on my previous trailer. Both have worked just fine. Ce's seem to be easier to add lights to. The VeVe's are by far the strongest and best built on the market, and the price reflects it.
Either way, get pads, and get them longer than you think you need. As the times you need them the most, will be on that ramp that is way deeper than expected.
Good luck.
HangOutdoors
Royal Oak, MI
agree with @biffdotorg I have the CE Smith 60" with the covers and they work great. I also have the same boat you do and trailer. I got the lighted caps on mine. Game changer in the dark.
AZMark
Phoenix, AZ
Veve guides on same trailer. Bought 60” and cut them down 6”.
I like that the whole tube can spin freely over the metal mount in the event you really jam the boat against them, but I think that eliminates the option of lights.
biffdotorg
Pelican Rapids, MN
View attachment 167825View attachment 167824
On my painted SeaDoo trailer, I painted the VeVe guides black with shaker can. All the hardware too. When I went to install them, I was just careful on how much paint I scuffed off in the process. It made them look stealthy and more factory.
I can't believe that was 10 years ago!
NoFla21
NE FL
@HangOutdoors, I noticed you installed your VeVe guides with them above the frame of the trailer. Do you have any issues with this? I just installed mine and I’m concerned it will hit the bottom of the boat. Below are photos. It looks almost equal to the bunk of the trailer.5ABD4DE4-1552-4EEC-8715-E633A75EF296.jpeg951C7C23-1848-40F6-9FEB-707CD77FCBCD.jpeg7976CC96-EAAC-4983-9EDE-1C1294938981.jpegAF39E119-2B4E-4DF2-B67B-AF3548CE2C8D.jpeg
HangOutdoors
Royal Oak, MI
I cut mine off with a sawzall with a fine tooth metal blade. Then I put black caps on the ends I got off of amazon. I put a some sealant on the black caps to hold them on, which probably wasn't needed. I also drilled a couple holes on each side underneath to let water escape if it ever got in there.
Made in USA Prescott Plastics 1 1/2” - 1.5" Square Rubber Hole Plugs, Vinyl End Caps, Black Rubber Cover for Metal Tubing, Fences, Rubber Caps for Glide Protection from Chairs and Furniture (4 Pack) (amazon.com)
Top Bottom
