Trailer under water due to flood. What do I need to do...
BobJohnson
Highland Park, il
Chaparral
VR
My trailer has been under water due to flooding at our lake since last Thursday. The water level is a good 3-4 feet deep at and in front of my trailer, so there is no way I can get it to dry land now. The water level crested today (Monday am), so my guess is my trailer will be under water for at least a full week.
The lake is a mud bottom, fresh water lake. The trailer is a dual axle, with sup-r-lube hubs and breaks.
My question is, what do I need to do to my trailer when the water recedes and I can get to it?
I have fresh grease in the bearings, but plan on putting another batch of fresh grease in. But, is that enough for the bearings? What about the breaks? Do they need any cleaning/attention? What else??
I guess, just any and all thoughts on what should be done to a trailer that has been submerged in water for a long period of time. There are many others than just I affected. So, in general, what would you do for your trailer in this situation?
( @Devildog is one for instance I know is facing the same issue)
im assuming the trailer is a 2015? I would think everything should be sealed and not leaking, so no water should get in the brakes or anywhere else its not supposed to.. I would disassemble the bearings if they are serviceable and grease them.. pressure wash the mud/dirt off everything else, check the wiring for the lights and what not and forget about it.
Take a good look at the brake fluid, if you suspect water contamination replace it and try to id where it leaked in from so you can address that too. Check to see if the lights still work as well.
