Trouble dropping anchor
Padawan Learner we have all been there at one time. Lots of good advice above.
Stay courteous, proceed slowly and avoid trying to slice a spot out between boats that you are not ready for and the Death Stares will be minimal.
Anchoring my 19' was embarrassing till I finally got it beat into my head that it wasn't the anchor it was Me, the Boat, the Chain, the Bottom and the Wind/Current/Tide. Using a traditional Danforth Anchor-8'Chain-Anchor Line-Boat set up and anchor in 20' to 2' depth mainly sand (some rocks/reef but thats another story). No matter how deep/shallow the chain must lay on bottom, its the key to the anchor biting when you attempt the "set". When strong winds/current/tide are in play my 19' can swing in a big arc so I will set another anchor at the stern and draw them tight.
Practice & Patience will pay off.
This is the way.
"This is the way"
-Din & Grogu
this is all you need for the ocean and sandy bottom
FX7
STAINLESS STEEL CHAIN
STAINLESS Anchor Shackle
I second this setup, though when I "lost" my FX7 I upgraded to the FX11. I did however have to trim it to get it to fit in the anchor box. I have never had an issue with this holding even in the strongest currents. They key is to have enough rope out for how deep the water is. Every time I pull up to the sand bar I feel like I put my anchor out way further than everyone else. However I never have issues with my boat going anywhere and it helps when tides change you can just pull the boat out a little bit and not worry about accidently pulling up your anchor.
Really cool until the teeth make their way to the other side of the fiberglass.
Put a $20 rubber liner in the locker. To me still way easier to set, needs almost no line and no chain.
Have you ever seen box anchor teeth sticking through a hull? It is not pretty. You have much more faith in a rubber liner than I.
