Emptytemples
- Easton, PA & Ocean City, MD
Hello All,
Having a minor issue with our new 250.
The throttles are slightly off with their position above idle. Trying to explain this, this may have terminology i'm not familiar with. The starboard throttle control has to be slightly forward of the port throttle control at anything above idle to sync the rpms. Has anyone run into this issue? There has to be an adjustment but I do not have the service manual yet. I see the throttle cable come through the front of the engine compartment into the throttle assembly or whatever that is called. That looks like it has an adjustment by moving the nuts to give or take away slack from the cable going to the control. I'm thinking about removing slack to the starboard cable by adjusting that. Could that solve my issue or is there another adjustment.
I'm trying to avoid going to a dealer for warranty for such a minor thing. I also have to adjust my friction on the remotes as well. The starboard doesn't pull back but the port throttle definitely loses position. I assume the friction adjustment is below the rubber caps in front of the levers. Otherwise, I will remove the plastic covers and figure out the friction adjustment.
Any help on either issue is appreciated.
