Paul Heltzel
- SX
I’ve got 2 things I’d recommend especially for new owners, or anybody having trouble keeping water out of the boat, especially on a lift, that have made my life much easier. These budget items stand out in the 10 years I’ve had my SX210.
I’ve used one of these for years with no issues:
www.pwcdoctor.com
No worries about forgetting the drain plug. And the engine compartment drains even if the bilge pump fails (critical to me because my boat is on a lift and even with a trickle charger shore power fails).
This dirt cheap cover is waterproof, light, and fits well. At this price I could replace it yearly if needed:
www.vevor.com
I put a cheap grommet in the back half of the cover so water will drain out the scupper valve. I just don’t want water on my seats or in the engine compartment during the offseason:
$13 grommet kit, dead simple
Water doesn’t pool up on the front panel, for some reason. This approach means I don’t have to mess with anti pooling straps or poles.
These might not appeal to everybody, but I like the minimum therapeutic dose to boat maintenance. These keep water out of places that can lead to serious damage, with minimal effort.
Now I just need to find a simple way to keep the cover on, when the boat’s on the lift.
I’ve had expensive Yamaha covers that let a lot of water in the boat. And I’ve had trouble with water pooling on covers. But no longer and both of these things are less than $40.
Keeping You From Sinking Without Thinking!! Versiplug from PWCDoctor.com Never Forget Your Plug
Versiplug The Original Self Bailing Drain Valve For Personal Watercraft and Boats Vacates the water from your hull. Keeping you from sinking without thinking. Never forget your drain plug again. Jet Ski Drain Plug #Versiplug #ThePWCDoctor #PWC #DrainPlug #Waverunner #Jetski #PersonalWatercraft #Boa
VEVOR Waterproof Boat Cover, 20'-22' Trailerable Boat Cover, Beam Width up to 106" v Hull Cover Heavy Duty 210D Marine Grade Polyester Mooring Cover for Fits V-Hull Boat with 5 Tightening Straps | VEVOR US
VEVOR Waterproof Boat Cover made from 210D marine-grade polyester offers full UV protection, tear resistance, and secure fit with 5 adjustable straps for 20'-22' V-Hull boats.
