JRuszkay
- SX
I was wondering if anyone else has experienced the engine speed varying by 1000 rpm or more when running at 6000-7500 rpm. This just started happening on my 2008 Yamaha SX210. It seems to occur during first 20 min of operation then go away. I am thinking it’s dirty spark plugs, gas fuel flow or a wire on starting to fail throttle position sensor. The engine speed will respond if I adjust the throttle position up and down, but then doesn’t hold steady once I leave it alone, until I run for 20 min or so, then the problem goes away. Wondering what is causing this issue.
