OUT ON THE REEF
- japon
- Other
- VRX
yes but you have to call Carslile the tire supplier they ware the ones that provided the tire and rims for the trailer if they are defected they will replace it but you have to make a video and send them a link and they will review it and you may be reimburse 'Wouldnt they be under warranty?
the aluminum rims i got they are machine maid not like the rims that came with the trailer they are welded and they wobble on the road and make a nasty vibrationI just had my tires replaced by Carslile. It was really easy. Just took a pick abd described the issue and they sent me 3 radial tires.
Whats defective on the tires and wheels on your trailer?
Same thing with me ,it rides alot better in the highway.The first mod I made to my trailer was remove crappy stock wheels and install aluminum ones with radial tires. On my last Yamaha I only changed the tires and kept the wheels. I was surprised when I took off the brand new wheels when I took delivery to see the back-sides already rusting. Since my average towing distance is 150-200 miles each way, I don't want bias ply tires on the trailer.
I'm guessing FSH 190 use the same combo as the SX and AR 190 boats do. If it's 13" wheel then it's the same setup. If it's 14" whee then it's the same as SX/AR 192/195. Bolt pattern should be 5x4.5". See this thread Replacing 13" tires with 14".Any idea of the stock wheel specs ?
Any pics of the new wheels I to am replacing my stock carlisle lh tires bias ply and wheels have about 400 miles on them it's amazing you pay 30,000 plus for a boat and get crap for tiresThe first mod I made to my trailer was remove crappy stock wheels and install aluminum ones with radial tires. On my last Yamaha I only changed the tires and kept the wheels. I was surprised when I took off the brand new wheels when I took delivery to see the back-sides already rusting. Since my average towing distance is 150-200 miles each way, I don't want bias ply tires on the trailer.
