I have the simrad GO 7 as well, but did not mount it to my dash, just used the RAM mount. As for VHF, I recommend getting a handheld for while you are on the island, as this is about the only means of communication. If you are looking for fixed mount, I like standard horizon. You will want the GX1700 or above for GPS/DSC. Personally, I am getting a GX 2200 this year to have AIS. The GX 2200 will communicate with your GO7 and provide AIS overlay of other boats. Sadly, this is the closest I am going to get to a radar this year. I have found Hodges Marine to have the best pricing, so add them to your favorites tab. Other than that, I am watching a WM-3 Sirius XM weather module to have a little more situational awareness while in the deep blue water this year.
@Yamaha212limiteds I recommend mounting your transducer under the ride plate. I originally mounted mine with the transom mount but @rsrlegends has me convinced that mounting to the ride plate is the best location. Transom mounting works well in functionality of the transducer, but creates a little drag on the boat and it is in my way for adding trim tabs. Rick, (@rsrlegends ) do you have any pics of your install location?
I think I'm going to have to copy you as well @rsrlegends. Seems like the only spot that will work for me. Doesn't look like you needed to remove the ride plate. Any issues with the install? I'm assuming you had to get some longer bolts. Any pro tips? Are you still able to get readings on plane?
I actually did remove the plate to drill and mount the transducer. Not that big of a deal but you need the right hex tool to remove it. No problems with readings at any speed/ condition.
