ricardoar190
Hello JB members,
I need your input and help on an issue that I been trying to solve since the day I got my first boat, a 2018 yamaha AR 190 with extended warranty. I have this vibration at around 2k to 3k that I figure it was normal as I have read throughout multiple forums that is could be normal from these Yamaha but something is still not quite right a you can see from video link below.
Things done so far to correct issue with no luck:
- dealer replaced intermediate bearing and I think coupler as well ( an ordeal but thats a different story) no actual difference in noise.
- I replaced jet pump liner with plastic ring ( a bit more quieter) but nothing significant.
- inspected jet pump bearings for water intrusion and seizing but found no issues. Also did the oil bath while at it since grease seem to do very little as far as lubing.
- spend lots of time and money on noise reducing stuff around engine and water box compartment with little help.
- replaced spark plugs and oil.
- check shaft for potential bend.
at this point I think the pump bearings are shot because the sound comes from the jet pump area when rev above 2k. When in the water the vibration stays all the way up until 3k approximately.
I want to bring it back to my local dealer but I will avoid at all cost since they are a mess to deal with and rather do the work myself.
Any thoughts I would appreciate it.
