Voltage reading with engine running
Robby
I have a 2016 ar192 and it is reading about 12.9 engine running. What is everyone else seeing for voltage with boat running?
tabbibus
Lake Lanier, GA
Mine is anywhere from 12.8 to 14 ish. But I think I;m having battery issues so wouldn't use me as a good example
Robby
Yeah my friends 2018 Yamaha ski reads 14 but I am never seeing close to that. I found a service manual for a older sx190 that’s says peak is 13v. Mine is a 2016 ar192 so just wondering what it should be.
Bransc1986
Spokane, Washington
Mine typically runs around 12.5 at idle but if I’m running her it will climb up a little over 14.
Beachbummer
Houston TX
Output varies with power, perhaps leave the voltage meter attached on the next trip and glance at it at greater RPM to see the effect?
Robby
Fixed! Battery just had a low charge. It puts out 14.1 even at idle.
tabbibus
Lake Lanier, GA
14.1 at idle is odd. Shouldn't it be 12.7 max if not being charged? I'm new to this, so I may be wrong.
Gunner
Southeastern, Mass
Only took it out once. Didn't notice voltage at idle but was over 14 v at cruising speed.
Robby
They should be 14 even at idle or else you have a bad connection or weak battery. My cousin just bought a new one also and it’s the same. This may not be true on older ones. Mine is 2016 and his is 2018
bronze_10
Raleigh / Wake Forest Area..
On my older boat if I have the battery switch selected to one battery it reads over 14.. if I change the switch to both batteries it drops to about 13 or so..
Beachbummer
Houston TX
It depends on battery state of charge at low rpms I believe. For a fully charged battery it has no trouble reaching 14v, but for a battery in need, it cannot do that at idle.
That's my theory.
Garrett C
Lakewood Ranch, FL
Mine is always hovering around 14 volts, never seen anything different.
ripler
Just south of Pittsburgh
MasterCraft
Not sure about the 1.8s but my MR1 is a little over battery voltage at idle and at 3500 the manual says it should be 13.
